Hockeyspeedyy Geschrieben 5. Juli 2015 Geschrieben 5. Juli 2015 Moin! Hat zufällig jemand von euch ein Datenblatt mit den Anzugsmomenten für die 1199? Fröhliches schwitzen noch! (party) Gruß ben ++
ph1l Geschrieben 5. Juli 2015 Geschrieben 5. Juli 2015 Frame tightening torques Part Thread (mm) Nm Tolerance ±10% Notes ACCESSORIES AND OUTFIT Passenger seat strap nut M6X1 8 Grease B (on underside only) STAND Side stand pivot pack fastener M8X1.25 25 Grease B Stand spring rod stop grub screw fastener M6X1 5 LOCK 8 Spring centring rod hinge pivot fastener Interference fit and caulking Side stand magnet fastener Glued with silicone and caulking CHAIN - SPROCKET Sprocket cover retaining screw M5X0.8 4 LOCK 2 Front sprocket retaining screw M10X1.25 55 * Grease B Chain slider retaining screw M6x1 13 LIGHT UNITS Screw securing conveyor to headlight M3.5 1 Screw securing headlight to support M5x0.8 5 Grease B Screw securing headlight to tail guard compartment M4.5 ST 3 Screw retaining mirrors to subframe M5x0.8 6 Screw retaining turn indicators to number plate holder M5x0.8 3 INSTRUMENT PANEL Nut retaining silent block to headlight support M5x0.8 3 FRONT FORK Steering shaft to bottom yoke fastener M37x1 40 LOCK 5 Screw retaining bottom yoke clamps to forks M6X1 8* Grease B (Sequence: 1-2-3 / 2-1-3) Nut retaining steering stop screw M6X1 10 LOCK 2 Screw retaining splashguard to bottom yoke M5x0.8 5 Screw retaining Ohlins fork bottom end clamps to shaft M8x1.25 19* Grease B Screw retaining steering head clamps to forks M8x1.25 22* Grease B Screw retaining steering head clamps to steering shaft M8x1.25 22* Grease B Ring nut retaining steering shaft pack M35x1 25* Grease C Screw retaining eyelet to Ohlins steering damper M8x1.25 10 LOCK 8 Screw retaining steering damper to frame M6X1 10 LOCK 1 Screw retaining steering damper to handlebar M6X1 10 LOCK 1 ELECTRICAL - ELECTRONIC SYSTEM Electrical system mounts to frame fastener M5x0.8 5 LOCK 1 Screw securing battery support to engine M6x1 10 Screw securing cover to battery support M5x0.8 5 Screw securing fuse cable protection to battery support M5 ST 3 Screw retaining cable eyelets to solenoid starter M6x1 4 Nut retaining cable eyelets to starter motor M5x0.8 3 Grease C Screw retaining wiring bracket to head M5x0.8 4 LOCK 1 Self-locking nut retaining solenoid starter support to generator cover M5x0.8 6 Screw retaining voltage regulator M6x1 8 Screw retaining control unit bracket M5x0.8 3 Coil screw M6x1 8 Map sensor screw M6x1 2 Screw retaining throttle shells M5x0.8 1,5 Screw retaining RH switchgear shells M4x0.7 1,3 Screw retaining LH switchgear shells M4x0.7 1,3 Side stand switch screw M4x0.5 3 LOCK 2 Ignition switch special screw M6x1 10 Pre-applied threadlocker on new part - LOCK 2 for reuse Speed sensor screw M6x1 10 Lambda sensor fastener M12x1.25 25 Pre-applied grease on new part - Grease B for reuse Number plate light retaining screws 3 0,7 Air temperature sensor screw M5x0.8 3 Rear stop switch fastener M8x1 5 Horn screw M8x1.25 18 Pre-applied threadlocker on new part - LOCK 2 for reuse Exhaust valve motor screw M5 ST 4 Screw retaining motor cover to extractor M5 ST 4 Screw retaining actuator to air-box bottom M5x0.8 4 Screw retaining secondary air system pipe support clamp M3.5 ST 1 Screw retaining wiring tab on LH seat-tank cover M4x0.5 2 Screw retaining GPS to instrument panel cover M4x0.7 1.5 FRONT BRAKE Screw retaining front brake master cylinder to handlebar M6x1 10 (Sequence: 1-(UP)-2-1) Brake fluid reservoir plate screw M6x1 10 Self-locking nut retaining brake fluid reservoir to plate M5x0.8 5 Screw retaining brake lines coupling to brake master cylinder M10x1 23 Screw retaining brake lines coupling to RH brake calliper M10x1 23 Screw retaining brake lines coupling to LH brake calliper M10x1 23 Braking system black bleeder M6x1 Screw retaining callipers to fork bottom end M10x1.25 45*/pre-torque 2* Grease B Screw retaining front brake line guide to bottom yoke M5x0.8 5 REAR SWINGARM Fastener retaining right-hand swingarm shaft to engine block M20x1.5 100* Grease B Fastener retaining left-hand swingarm shaft to engine block M20x1.5 100* Grease B Chain slider retaining screw M6x1 8 Pre-applied threadlocker on new part - LOCK 2 for reuse Lower chain splashguard screw M6x1 8 Pre-applied threadlocker on new part - LOCK 2 for reuse Upper chain splashguard black screw M5x0.8 5 Pre-applied threadlocker on new part - LOCK 2 for reuse Screw retaining swingarm clamp to eccentric M12x1.25 25* Grease B (Sequence: 1-2-1) Calliper holder plate reference pin fastener M12x1.25 33* LOCK 8 REAR BRAKE Union retaining screw M10x1 23 Rear brake fluid reservoir screw M6x1 2 Front screw retaining brake master cylinder support to footpeg bracket M5x0.8 6 Use pre-torque setting Rear screw retaining brake master cylinder support to footpeg bracket M6x1 10 LOCK 1 Screw retaining rear brake master cylinder to support M6x1 8 Screw retaining rear brake calliper to plate M8x1.25 25* Grease B Screw retaining rear brake line guide to swinging arm M5x0.8 3,5 LOCK 2 Special nut retaining brake line grommet to clutch cover M5x0.8 5 Rear brake line guide tie fastener M6x1 8 ABS Fastener retaining ABS bracket to horizontal head M6x1 10 Fastener retaining ABS control unit rubber block to support bracket M6x1 8 Fastener retaining ABS brake lines to control unit M12x1 23 Fastener retaining ABS brake lines to control unit M10x1 23 Front fastener retaining ABS compartment cover M5x0.8 3 Rear fastener retaining ABS compartment cover M5x0.8 5 Fastener retaining front and rear ABS line grommets to frame M6x1 5 LOCK 2 NUMBER PLATE HOLDER Screw retaining lower to upper number plate holder M5 ST 5 Screw retaining number plate holder to subframe M5x0.8 6 Screw retaining number plate holder plate to number plate holder M6x1 5 Nut retaining cat's eye to number plate holder plate M4x0.5 2 HANDLEBAR - CLUTCH CONTROL Screw retaining clutch master cylinder to handlebar M6x1 10 Sequence 1 (UP)-2-1 Clutch fluid reservoir plate screw M6x1 - Nut retaining brake fluid reservoir to plate M5x0.8 - Union retaining special screw M10x1 - Braking system bleeder M6x1 - Union retaining screw M10x1 - Screw retaining clutch slave cylinder to engine block M6x1 10 Sequence: 1-2-3-1 Screw retaining handlebar clamp to fork M8x1.25 22* Grease B Screw retaining handlebar clamp to tube M6x1 8 Grease B (Sequence: external-internal-external) Fastener retaining counterweight to handlebar M18x1.5 25 LOCK 1 REAR SUSPENSION Screw retaining support to engine block M8x1.25 25* Grease B Screw retaining rocker arm halves to LH support M8x1.25 60* Grease B Special screw retaining suspension reaction rod clamp M6x1 10* Grease B Special screw retaining suspension linkage to swingarm M10x1.25 45* Grease B Nut retaining suspension linkage to rocker arm M10x1.25 45* Grease B Screw retaining shock absorber to engine block M10x1.5 45* Grease B Screw retaining shock absorber to rocker arm M10x1.5 45* Grease B Screw retaining shock absorber spring guard M5x0.8 6 Rear suspension linkage centre distance adjustment M14x1 GREASE C FRONT MUDGUARD Mudguard clip retaining screw M3.5 ST 0,4 Screw retaining mudguard to bracket M6x1 10 RADIATOR Screw securing radiator support to frame M5x0.8 6 Grease B Black screw with wide head retaining radiator support to horizontal head M5x0.8 4 LOCK 1 Black screw retaining radiator support cover M5x0.8 2,5 Screw securing top radiator to radiator support M5x0.8 5 Grease B Screw retaining heat exchanger breather pipe eyelet M10x1 14 Screw retaining electric fan to front extractor M5 ST 3 Screw retaining rear extractor to front extractor M5 ST 4 Screw securing extractor to radiator support M5x0.8 5 Grease B Black screw retaining extractor to sump M5x0.8 4 Pre-applied threadlocker on new part - LOCK 2 for reuse Screw on clamp retaining water pipes to radiators and distributor - 2,5 FOOTPEGS AND LEVERS Screw retaining LH support to engine block M8x1.25 25* Grease B Screw retaining LH support and stand to engine block M8x1.25 25* Grease B Screw retaining LH support clamp to swingarm shaft M8x1.25 8* Grease B Screw retaining LH footrest holder plate to support M8x1.25 25* Grease B Screw retaining LH heel guard to footrest holder plate M5x0.8 6 Pin retaining gearchange pedal to footrest holder plate M8x1.25 25 Grease C on collar Nut retaining ball joint to rod M6x1 5 LOCK 1 Nut retaining quick-shift actuator to rod M8x1.25 15 LOCK 1 Screw retaining complete rod to gearchange pedal M6x1 10 LOCK 1 Screw retaining complete rod to gearchange transmission lever M6x1 10 Screw retaining gearchange transmission lever clamp to selector shaft M6x1 10 Screw retaining RH support to engine block M8x1.25 25* Screw retaining RH support clamp to swingarm shaft M8x1.25 8* Grease B Screw retaining RH footrest holder plate to support M8x1.25 25* Grease B Rear screw retaining RH heel guard M5x0.8 6 LOCK 2 Front screw retaining RH heel guard/cylinder support M5x0.8 6 LOCK 2 Pin retaining rear brake lever to footrest holder plate M8x1.25 25 Grease C on collar Nut retaining rear brake lever adjuster screw M6x1 8 Nut retaining fork to rear brake linkage M6x1 7,5 Pin retaining rear brake linkage to brake lever M6x1 10 LOCK 2 Screw retaining passenger footpeg holder plates M6x1 10 Front screw retaining footrest holder plates to subframe M8x1.25 25 Rear screw retaining footrest holder plates to subframe M8x1.25 25 REAR MUDGUARD Black screw retaining rear mudguard to swinging arm M5x0.8 5 Pre-applied threadlocker on new part - LOCK 2 for reuse FRONT WHEEL Screw retaining brake discs and phonic wheel to wheel rim M8x1.25 30* Nut retaining front wheel pack to LH fork leg M25x1.25 63* Grease B (on thread and underside) REAR WHEEL Special screw retaining driving pin M8x1 25* DRILOC 218 on new part - clean and LOCK 2 for reuse Rear phonic wheel retaining screw M5x0.8 5* LOCK 2 Rear sprocket cush drive damper nut M10x1 44 LOCK 2 Rear wheel nut (sprocket side and wheel side) M48x1.5 230* Grease B (on thread and underside) Rear wheel eccentric More GREASE C FUEL TANK Tank rear pivot fastener M8x1.25 18 Male quick coupling fastener 1/4 NPT 5,5* LOCK 6 Tank front hinge spacer retaining screw M6x1 10 Grease B Tank plug screw M5x0.8 4 Tank support top bracket front nut M5x0.8 6 Tank support top bracket rear screw M6x1 10 Grease B EXHAUST Copper nut retaining manifold to head M6x1 10 Screw retaining heat guard to horizontal manifold M5x0.8 5 CO plug fastener G 1/8" A 25 Grease I Copper nut retaining manifold to head M6x1 10 CO plug fastener G 1/8" A 25 Grease I Screw retaining exhaust silencer to central body M6x1 10 Nut retaining front bracket to silencer M6x1 10 Screw retaining silencer front bracket to engine block M8x1.25 25 Grease B Screw retaining rear bracket to silencer M6x1 10 Screw retaining silencer rear bracket to engine block M8x1.25 25 Grease B Screw retaining heat guard to vertical manifold M5x0.8 4 Self-locking nut retaining Bowden cable heat guard to sump screws M5x0.8 6 Fastener retaining silencer bracket to footrest holder plate (Japan version) M5x0.8 6 LOCK 2 Fastener retaining silencer bracket to carbon tailpipe (Japan version) M6x1 15 Fastener retaining tailpipe bracket spring unit to silencer bracket (Japan version) M8x1.25 15 Fastener retaining heat guard to carbon tailpipe (Japan version) M5x0.8 4 SEAT Black screw retaining seat spacer to tank bracket M5x0.8 5 FRAME Nut retaining frame to cylinder heads M10x1 45* Grease B Side screw retaining switch bracket to frame M6x1 10 Grease B Central screw retaining switch bracket to frame M6x1 10 Grease B Screw retaining rear subframe to frame M8x1.25 28* Grease B Screw retaining rear subframe to vertical head M8x1.25 22* Grease B Screw retaining secondary air system pipe tab M4 ST 2 Special screw retaining tail guard compartment to rear subframe M8x1.25 18 Special screw retaining tank support bottom bracket to rear subframe M6x1 10 Grease B Nut retaining seat lock revolving plug to side body panel M22x1.5 3 Screw securing seat latch to tail guard compartment M6x1 8 AIR INLET/OIL BREATHER Bottom screw retaining front subframe to frame M6x1 10 Grease B Top screw retaining front subframe to frame M6x1 10 Grease B Screw retaining instrument panel cover to front subframe M5x0.8 3 LOCK 1 FUEL SYSTEM Screw retaining throttle body to intake manifolds M6x1 10 LOCK 1 Nut retaining intake funnels to throttle body M5x0.8 6 Screw retaining injector caps to throttle body/shower M5x0.8 6 Screw retaining fuel supply unit to fuel tank M5x0.8 5 Grease B Fastener retaining ABS bracket to horizontal head (USA-CAL) M6x1 10 Fastener retaining canister bracket to ABS special screws (USA-CAL) M5x0.8 6 FAIRING Screw retaining headlight fairing to subframe M5x0.8 5 Screw retaining Plexiglas to headlight fairing M4x0.5 0,2 Screw retaining headlight fairing splashguard to headlight M5x0.8 5 Black special screw retaining LH upper half-fairing to headlight fairing M5x0.8 2,5 Black special screw retaining LH upper half-fairing to electrical system support M5x0.8 2,5 Black special screw retaining LH upper half-fairing to lower half-fairing M5x0.8 2,5 Black special screw retaining LH lower half-fairing to LH support M5x0.8 5 Black special screw retaining LH lower half-fairing to rear extractor M5x0.8 2,5 Black special screw retaining RH upper half-fairing to headlight fairing M5x0.8 2,5 Black special screw retaining RH upper half-fairing to electrical system support M5x0.8 2,5 Black special screw retaining RH upper half-fairing to lower half-fairing M5x0.8 2,5 Black special screw retaining RH lower half-fairing to RH support M5x0.8 5 Black special screw retaining RH lower half-fairing to rear extractor M5x0.8 2,5 Special screw securing lower half-fairings to radiator support M5x0.8 2,5 Side black special screw securing half-fairings to radiator support M5x0.8 2,5 Black special screw retaining LH side body panel to subframe M5x0.8 2,5 Black special screw retaining LH side body panel to tail guard compartment M5x0.8 2,5 Black special screw retaining RH side body panel to subframe M5x0.8 2,5 Black screw retaining RH side body panel to tail guard compartment M5x0.8 2,5 Black screw retaining tail guard frame to tail guard compartment M5x0.8 2,5 Black screw retaining tail guard frame to tail guard side body panels M5x0.8 2,5 Special nut retaining ignition switch cover to bracket M5x0.8 8 Fastener retaining switch cover to conveyor covers M5x0.8 2.5 Fastener retaining Japan sound-deadening panel to engine M5x0.8 5 * critical point for dynamic safety. Tightening torque tolerance must be ±5%. ++
Hockeyspeedyy Geschrieben 6. Juli 2015 Autor Geschrieben 6. Juli 2015 Oh........ mein........ Gott......... |-( das ist aber ne Menge Holz.... Danke dir! ++
